SecuExtender IPSec Windows VPN client suddently will not connect
2»
  • OWB
    OWB Posts: 40 image  Freshman Member
    @PeterUK I did notice that too, but really don't know what have changed in between, expect for doing reprovisioning a couple of times. :-(
    The non expired cert is the one in use.
    PeterUK Posts: 4,411 image  Guru Member
    Did you select that new cert in the VPN gateway settings too? also downloaded the new cert for the client?
  • OWB
    Yes, it was changed at the same time it got issued, because the old one has expired. When doing a provissioning from the IPSec client, it's my understanding that the certificate is aquried from the VPN 100. After that it has been working well until end of last week.
