FlexH 1.36 uOS - missing period time check connectivity
GiuseppeR
GiuseppeR Posts: 664 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
edited December 2025 in Security Ideas
Hello everyone,
on Nebula there is NOT the "Period" of time about checking WAN connectivity.
For example you want shorter time than the default 30 sec:
So the only way to modify it is via local UI
3 votes
Active · Last Updated
  • Zyxel_Tina
    Zyxel_Tina Posts: 702 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @GiuseppeR,
    Thanks for your input! We have moved the request to the appropriate section for better visibility. We will continue to monitor the votes and comments as part of our evaluation process.
    If anyone likes this idea, please show your support by leaving a comment or voting for it.
    Zyxel Tina
  • GiuseppeR
    Hi @Zyxel_Tina
    thanks for that update
