FlexH 1.36 uOS - SecuReporter options on local UI
GiuseppeR
GiuseppeR Posts: 664 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
edited December 2025 in USG FLEX H Series
Hello everyone,
as you can see NOT all the settings of SecuReporter are flagged:
Is there a chance to enable all of them via Nebula or only via local UI?
  • Zyxel_Tina
    Zyxel_Tina Posts: 702 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @GiuseppeR,
    After confirmation, these settings can only be enabled via the local GUI. Nebula does not have options for this functionality.
    If you'd like these additional settings to be configurable directly in Nebula, please let us know your specific needs. We will forward your requirement as a Feature Request to our development team for evaluation and create an Idea Post for you to gather feedback.
    Zyxel Tina
  • GiuseppeR
    Hi @Zyxel_Tina
    I think that if you want to integrate Nebula and FlexH series you should allow, from Nebula, to send all the FW statistics to SecuReporter. It is a basic need to monitor on site security. If you select send "Traffic log" from website:
    I saw NO flag on local option:
    So I had to flag those empty box manually.
    Nowadays I still have to mix local and remote configs on FlexH series, it is an improvement compared to the past because with the previous firewalls I had limited option local UI when they are linked to Nebula (to give you an example a Flex series).
    With newest firewall you have complete UI also locally (very good choice!) but it could be better to have at least basic functions fully configurable online (like this SecuReporter statistics collection).
    Just my opinion 😁
  • Zyxel_Tina
    Hi @GiuseppeR,
    Please allow me to clarify, the SecuReporter settings on NCC currently apply to USG FLEX / ATP Series and USG LITE 60AX only. This is why the configuration you changed in NCC does not take effect and sync to your USG FLEX H firewall .
    Regarding your requirement, we will convert this into a feature request and create an idea post so we can gather feedback as part of our evaluation process. If anyone likes this idea, please show your support by voting for it or leaving a comment.
    Thank you for your understanding and feedback.
    Zyxel Tina
