Cascading between a FortSwitch 124F and a Zyxel GS220-50
Dear Sir/Madam,
I am experiencing difficulties establishing cascading between a FortSwitch 124F and a Zyxel GS220-50 using the SFP/GBIC ports. During testing, we identified that the Zyxel's SFP port is only negotiating 100 Mb, which prevents communication with the FortSwitch, which requires a minimum negotiation of 1 Gb.
Below is a summary of the diagnosis already performed by the TeleData technician:
The FortSwitch 124F is operating normally; the parameters have already been adjusted to speed 1000/full and inspections have been removed.
The GBICs were tested on other switches (TP-Link and Cisco) and negotiated 1 Gb normally, ruling out physical defects in the modules.
On the Zyxel GS220-50, SFP port 47 remains negotiating at only 100 Mb, even when using a 1 Gb GBIC.
SFP ports 49 and 50 were also tested; however, no LEDs light up and the negotiation does not increase to 1 Gb.
The VLANs on the FortSwitch are correct, with the port configured to pass the local VLAN (untag).
Current suspicion: possible limitation or configuration on the GS220-50 that is restricting the negotiation of the SFP ports.
Hi @edivelton
What's your SFP model? Additionally, we don't have a model call GS220-50. Could you help to provide the correct model's name?
Also, please try to connect a loop to test the Zyxel switch with the SFP module. This can compare if the switch has any issue. We also test GS2220-50 with Zyxel SFP module SFP-SX-D, which is connecting at 1 Gb.
Zyxel Melen0 -
Hi @edivelton
You can also fix the port speed to 1G/Full on the Zyxel switch SFP port. It could be because the SFP model's info is not in the format we can recognize.
Zyxel Melen0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 348 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
