Virtual Address Mapping on SSL-VPN
SIGIL
SIGIL Posts: 1 image  Freshman Member
First Anniversary
edited April 2021 in Security
with a zywall 35, when I want to create a VPN between 2 LAN of the same address, there was a parameter 'Virtual Address Mapping Rule' that allowed it. On a USG 60 how can you do it?
Regards
Jean-Louis
  • Zyxel_Stanley
    Hi @SIGIL
    The SNAT and DNAT rule configuration is at advance setting of VPN Connection(phase 2).
    You can setup it when both of sites are using the same IP subnet.
