DHCP, Gratuitous ARP, and Proxy ARP with XP
Yes XP is dead but I
use it for testing and does a odd Decline for DHCP with this setup
that WIN 7 & 10 or Ubuntu are fine with but found a reg key that
fixed XP so I wanted to post this to show the problem I was having.
The setup is with a ZyWALL 110 and a port based VLAN like this:
https://businessforum.zyxel.com/discussion/comment/4580/#Comment_4580
With a VLAN 18 setup with set to Interface type general:
192.168.255.49/255.255.255.240
DHCP server
IP pool start address 192.168.255.50 pool size 3
Default router vlan18 IP
Enable Proxy ARP
192.168.255.48/28
Here what happens with win 10 that works fine
Here what happens with win XP
As you can see XP fails but with this registry key
https://www.itprotoday.com/compute-engines/how-can-i-disable-gratuitous-arp
it works!
So I was wondering if anything can be done on the USG/ZyWALL that would allow clients like XP to just work?
Hi @PeterUK
Gratuitous ARP is requested from DHCP client for check if IP address is duplicated or not.
Gratuitous ARP Relay is unable disable on ZyWALL.
I bet you can in firmware override the Gratuitous ARP to not send it out.
Its odd that WIN 7 & 10 or Ubuntu run fine with the setup but not XP.
Hi @PeterUK
I will send you private message for check your test environment more details.
Hi @PeterUK
I tried to setup your environment in my lab.
But strange thing is GAPR did not reply to me after PC received IP address.
Can you describe your switch configuration setting to me?
Do you have a switch setup with port based VLAN and isolation between the ports?
Are you testing with XP as win 7 & 10 are fine?
Is proxy ARP enabled with 192.168.255.48/28 entered?
Will post a draw up soon
Ok here the setup
Also their is a bug with Proxy arp
https://businessforum.zyxel.com/discussion/2734/proxy-arp-bug-not-applying-on-power-on#latest
Hi @PeterUK
Thanks for shared your configuration of this scenario.
The proxy ARP function will reply all ARP request which belonging to 192.168.255.48/28 subnet.(Including Gratuitous ARP)
It may leads client unable get IP address after received Gratuitous ARP reply.
At currently almost OS will ignore Gratuitous ARP reply packets (maybe OS will check If DHCP server and GARP MAC address are the same one)
So Win7/Win10/Linux are able get IP address successfully.
I will add it as idea for disable Gratuitous ARP reply in DHCP scenario.
Ok good that disable Gratuitous ARP reply will be a option for such clients.
- 439 Beta Program
- 2.8K Nebula
- 202 Nebula Ideas
- 6.3K Security
- 515 USG FLEX H Series
- 328 Security Ideas
- 49 Wireless Ideas
- 289 Service & License
- 459 News and Release
- 4.3K FAQ
- 97 Security Highlight
