Random latency handling delays on FLEX H at low bandwidth
Hi Melen
I don't know why you think that would help but it didn't as DNS does not go from DMZ to WAN1 but to test your case so that DNS does go by DMZ to WAN1 using
1.1.1.1(seems that edge is doing in the clear TCP for 1.1.1.1 interesting…) 8.8.8.8 is all UDP the issue still happens0 -
Hi @PeterUK
Based on our replicate, it was improved after this change. To investigate further, could you provide a remote PC for us to check?
Zyxel Melen0 -
Sure I get back to you on that other DNS issue is fully looked into.
PM sent for testing
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
