[USG Flex H] - Export to external services some usefull metrics
Maverick87
Maverick87 Posts: 98 image  Ally Member
edited October 2025 in Security Ideas
Hello everyone,
I've a domotic house, in which I have Home Assistant as my central hub to manage curtrains, lights, networks devices, electrical plugs and so on.
It's interesting to have some metrics on about the network performances, external WAN IP, how many devices are connected, and somethings help to manage the network on one hub.
It's also interesting try to manage some function directly from the hub (restart network, restart WAN interface, or somethings else)
Can be an idea to export all those metrics in any manner out from the firewall? Or Nebula just expose somethings similar?
Thank you
1 votes
Active · Last Updated
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,602 image  Zyxel Employee
    Hi @Maverick87
    Home assistant seems can use SNMP to get device's info and use automantion to display with visual. However, we are not familier with home assistant, you might need to investigate it yourself.
    Zyxel Melen
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    @Zyxel_Melen an easy accessible MIB file with documentation could be useful for managing SNMP data.
  • Maverick87
    Hi @Zyxel_Melen ,
    You're right, I've explored now the SNMP Info with SNMPWalk.
    I've all the OID, but I don't have the mapping between an "human-readable" name and the OID referred.
    I've downloaded also the MIB Files but isn't usefull, there isn't a key-value map for map the OID and what are the key referred.
    You have a guide or manual about how to map the OID?
    Thank you
  • Zulgrib
    Zulgrib Posts: 48 image  Freshman Member
    First Answer First Comment Friend Collector Fifth Anniversary
    You might want to check what librenms do with the MIBs.
