Proxy ARP bug not applying on power on
Had a power cut with UPS but the power went off for longer so the Zywall 110 went off, it came back on but my VLAN18 with Proxy ARP with 192.168.255.48/28 did not apply.
Workaround remove 192.168.255.48/28 from proxy arp then re-add 192.168.255.48/28 for things to start working again.
Hi @PeterUK
We have addressed this issue and fixed it in 4.33WK19.
ftp://ftp.zyxel.com/ZyWALL_110/firmware/433AAAA0ITS-WK19-r88384.zip
You can upgrade to this patch and issue will gone.
And also will fix in next FCS firmware too.
Yes that's fixed that issue thanks
- 434 Beta Program
- 174 Nebula Ideas
- 418 USG FLEX H Series
- 297 Security Ideas
- 43 Wireless Ideas
- 269 Service & License
- 416 News and Release
- 87 Security Advisories
- 4.1K FAQ
- 87 Security Highlight
