How can i move configuration from USG310 to another USG310?
Hi everyone,
i need to swap 2 usg310 and i want to copy the configuration from the old unit to the new one. Which is the right procedure? At the moment all my attemps gone wrong.
Thanks in advance for your help.
You can go to Maintenance > File Manager > Configuration File > Select “startup-config.conf” and Download it.
Rename configuration and Upload to another USG310 in the same path.
Click “Apply” button after selected configuration which you uploaded.
Note: Make sure both of USG310 are working on same firmware version to prevent applying configuration fail.
Thanks for your reply Stanley,
this has been my first attempt...
but the device reboot takes a long long time and ends with errors. I think it depends from certificates and all the setups that cannot be replaced on the new unit.
I think i have to handle the device via console port
If you have imported any certificates before, you have to imported certificates into new unit first. Otherwise it will apply configuration fail.
You can also share console log to us to make sure if there is others reason leads it.
- 588 USG FLEX H Series
- 476 News and Release
