Manual configuration of OpenVPN server
Zulgrib
Zulgrib Posts: 48 image  Freshman Member
First Answer First Comment Friend Collector Fifth Anniversary
We currently have very limited say on what is going on with the OpenVPN server, being able to modify manually the config (even if only available from command line) would be great.
Some users might need different split tunnel configuration.
2 votes
Active · Last Updated
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,650 image  Zyxel Employee
    Hi @Zulgrib
    Seems like you want to more configurable setting for SSLVPN? Could you share your use case/scenario with us?
    Zyxel Melen
