Proxy ARP bug not applying on power on
Had a power cut with UPS but the power went off for longer so the Zywall 110 went off, it came back on but my VLAN18 with Proxy ARP with 192.168.255.48/28 did not apply.
Workaround remove 192.168.255.48/28 from proxy arp then re-add 192.168.255.48/28 for things to start working again.
Hi @PeterUK
We have addressed this issue and fixed it in 4.33WK19.
ftp://ftp.zyxel.com/ZyWALL_110/firmware/433AAAA0ITS-WK19-r88384.zip
You can upgrade to this patch and issue will gone.
And also will fix in next FCS firmware too.
Yes that's fixed that issue thanks
- 383 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 76 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 895 Nebula FAQ
- 415 Security FAQ
- 233 Switch FAQ
- 205 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
