[USG Flex H] - Create Object Address based on MAC Address
Hello everyone,
I've the USG Flex 200HP from some months and I've difficulty to understand the Object Address of type "Host".
I mean, if I need to create some Control Policy rule based on some "device", I need to configure the device as Static DHCP based on Mac Address, and than configure an object address based on the IP Address.
But, I think is more convenient directly create an object address based on MAC Address, so in this way, I don't need to "force" the Static DHCP entry and if the device change it's own IP Address, the device is always managed by it's own MAC Address.
Yes its also like NAT mapping could be MAC based meaning the IP could change but forwarded under MAC by lookup table
Hi all,
Thank you for your input and feedback!
The idea of using MAC addresses to identify devices makes logical sense.
However, firewall policies work at Layer 3/4 (IP-based), while MAC addresses operate only at Layer 2 and are not preserved once traffic passes through a router or firewall. For this reason, USG Flex H series devices (like all L3 firewalls) cannot reliably enforce security policies based on MAC addresses.
Zyxel Tina
Hi Tina
This whole layer thing is really not a problem its just said to be take a L2 switch even your switches you can do L2 and L3 and ports control in ACL/Classifier how does that make it only a L2 switch? Also NAT on any router changes the MAC packets at L2 so how does that make it a L3?
And back when I had a Ubiquiti edgerouter-lite it could do control of source MAC for firewall rule control.
However you could, in any case, "translate" the MAC into the IP, you can use the DHCP list to know the IP.
Hi @Zyxel_Tina,
do you have an ETA for this request?Thank you
Hi @Maverick87,
The feature has not been determined yet. We'll continue monitoring the votes and comments to assess and prioritize this request.
We appreciate your patience and understanding!
Zyxel Tina
Meanwhile I added a demo how you can do NAT forwarding by MAC on myhttps://bridgemode.base44.app/NetworkLayoutBuilder
You can right click port 1 Configuration to view Virtual Server Configuration rules can do send packet for testing and change IP and it tracks by DHCP server tab on ports 5 and 6 by either Active DHCP Leases or Static IP (Gateway ARP) for firewall 1 to know the MAC for the IP that MAC is on.
- 236 Nebula Ideas
- 6.8K Security
- 739 USG FLEX H Series
- 376 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 91 About Community
- 119 Security Highlight
