100H - block external IP address ... not all IP's are blocked !
13»
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,539 image  Zyxel Employee
    Hi @SiegfriedH
    Thanks for sharing your profile. The reason you didn't see the IP Reputation Malicious connection:External Block List(Profile xxxx) log is because you disabled log function for block list in the Security Services > Reputation filter > IP Reputation. Although there's no log, the IP reputation is working and blocks the malicious connection. You may change to "log" from "no" to verify it.
    I will ask our team to improve the UIUX for the External block list.
    Zyxel Melen
  • SiegfriedH
    SiegfriedH Posts: 13 image  Freshman Member
    Done, hope this will solve the problem.
    TNX a lot
  • SiegfriedH
    edited January 9
    Hello Melen,
    seem to be OK and correct working now.
    It's confusing what needs to be checked and where… should be much more easier.
    TNX a lot
    Siegfried
  • Zyxel_Melen
    Hi @SiegfriedH
    I agree it is confusing. That's why I ask our product team to enhance the UIUX of the External block list page. It seems many users think this is an independent feature from the reputation filter, but it is not.
    Zyxel Melen
