No internet on LAN2 - Zywall USG 20
cpg_juraj
cpg_juraj Posts: 19 image  Freshman Member
edited April 2021 in Security
Hello.
I am fairly new to zywall. I am trying to enable LAN2 interface on USG 20. LAN1 works great and it is on 192.168.51.x. My intention is to enable LAN2 and separate it from LAN1 as it is going to be a guest internet (wifi). I have enabled the interface, change the subnet to 192.168.2.x, assigned DNS and DHCP pool. While the DHCP does it's job and assignes IP addresses to clients, there is no Internet. Any help is appreciated. Thank you.
    PeterUK Posts: 4,267 image  Guru Member
    Do you have a firewall policy setup to allow LAN2 to WAN?
    In Network > Routing you may need to make a rule for LAN2 to SNAT to WAN.
    Incoming = Interface
    member = LAN2
    Next hop
    Type = Interface
    Interface = WAN
    Address Translation
    Source Network Address Translation = outgoing-interface
  • cpg_juraj
    Hi. Thank you so much for your advice. Please see attached if I correctly created the rules.
    Looks correct.
  • Zyxel_Stanley
    Zyxel_Stanley Posts: 1,435 image  Zyxel Employee
    Hi @cpg_juraj
    How about test result after added policy route rule?
    Do LAN2 clients are able access to internet?
  • cpg_juraj
    Yes of course. That was my intention but I got to testing just last night. All worked great. Thank you PeterUK
  • Zyxel_Stanley
    Hi @cpg_juraj
    It's good to know your issue has resolved. 😃
