Disconnect after DCS
2»
  • Zyxel_Tina
    Zyxel_Tina Posts: 723 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @saltet,
    Please allow me to clarify: DCS is a feature where the AP detects interference, finds the clearest channel, and switches to it. The process works like this:
    • The AP stops sending Beacons and management frames on the original channel, causing clients to temporarily lose the signal.
    • The AP starts Beacons on the new channel, and clients must rescan and reconnect.
    This means any channel change will cause a brief disconnection and reconnection for clients—it's expected behavior, not a bug or malfunction. Clients don't "stay connected seamlessly" during a channel switch.
    Regarding DCS Client Aware (which I mentioned in the previous comment): This feature prevents channel changes if clients are actively connected, minimizing disruptions. However, in your setup with Smart Mesh and 24/7 client connections, it will have no effect. Therefore, we suggest disabling the DCS option as discussed earlier.
    Thanks for your understanding!
    Zyxel Tina
  • saltet
    saltet Posts: 76 image  Ally Member
    I have disabled DCS and and all de devices keep connected - for the last couple of days.
    The main question is why som of the devices didn’t reconnect after DCS.
    I now keep it as it is - without DCS.
  • Zyxel_Tina
    Hi @saltet,
    Devices disconnecting during DCS channel changes but not auto-reconnecting to APs is client-side behavior. From the logs, your heat pumps disconnected around 3AM due to the config change, then successfully reconnected (to this AP or others) and operated normally.
    Zyxel Tina
