SAML integration to Microsoft Entra ID with VPN authentication
We would like to request the implementation of SAML 2.0 support in the Zyxel USG H Series firewalls to enable Client VPN authentication via Microsoft Entra ID.
Currently, achieving this setup requires our customers to deploy a costly Site-to-Site VPN to Azure and maintain Microsoft Entra Domain Services, which adds complexity and expense. Competing vendors, such as Fortinet, offer native support for SAML 2.0 in their firewalls, making it significantly easier to integrate with modern identity providers like Microsoft Entra ID.
We believe that adding SAML 2.0 support to Zyxel’s product line would greatly enhance its competitiveness and usability in modern cloud-integrated environments.
Hi @Rebbe,
Thank you for your input!
After checking, Microsoft Entra ID integration will be supported in the next firmware release (v1.37). Please note that this implementation will use OAuth 2.0 instead of SAML 2.0.
Zyxel Tina
Will it be generic OAuth 2.0 or Entra specific ?
Hi Tina. Once again, I just have to say that Zyxel is disappointing. Only SSL VPN is supported in the new version 1.37 firmware 🙄🙄🙄. We need IPsec Client VPN to be able to log in using Microsoft Entra ID — why isn’t that just a standard feature? I really don’t understand it.
Hi @Rebbe,
Thank you for your feedback—we truly appreciate it and understand your frustration with the VPN options in firmware 1.37.
After checking, we confirm that IPsec Client VPN with Microsoft Entra ID integration requires extensive customization, which is not in our current roadmap. We're focusing on enhancing SSL VPN as the standard, secure solution instead.
Therefore, please use SSL VPN with Microsoft Entra ID. Alternatively, if you would like to use 2FA, you may refer to this article to integrate VPN client authentication with Duo Security’s 2FA:
Zyxel Tina
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
