usg flex h new firmware 1.37
hi I've updated my devices in ha pro configurations and I had a problem on some services configured on them. there is anyone that had installed it and tested it?
thank you.
Hi @MassimoRiva,
I understand you're experiencing issues with some services after updating your USG FLEX H series devices in an HA Pro configuration to firmware 1.37.
When updating firmware on USG FLEX H series devices in an HA configuration, it's crucial that both devices are running the same firmware version. If there's a firmware mismatch, the HA pairing will show an error. The USG FLEX H series also has a configuration rollback feature for firmware versions 1.30 and above, which reverts to the previous working configuration if the new configuration fails to apply.
To help us investigate this issue further, please provide the following information:
- Device Models: Please specify the exact models of your USG FLEX H series devices.
- Current Firmware Version: Confirm that both devices are currently running firmware version 1.37.
- Detailed Problem Description: What specific services are experiencing problems? Can you describe the symptoms you are observing?
- Network Topology: A diagram or description of your HA Pro setup, including how the devices are connected and the heartbeat port used.
- Error Messages: Any error messages displayed on the device dashboard or in the event logs.
- HA Status: The current HA status from
System > Device HA > HA Statuson the primary device. - Diagnostic Logs: If possible, please download the diagnostic logs from both devices by navigating to
Maintenance > Diagnostics > Diagnosticsin the web GUI and clicking "collect now."
Additionally, if your devices are managed by Nebula, please enable Zyxel Support Access:
- Go to
Help > Support Requestin the Nebula console. - Provide your Organization and Site name.
Enabling Zyxel Support Access allows our support team to directly view your cloud environment configuration, which can significantly expedite the troubleshooting process.
If you have feedback or idea about this AI assistant, share them in Community Feedback.0 -
hi, sorry for the delay; we have found the problem : the arp table of the device of our provider was dirty the access to our perimetral firewall was blocked/allowed and after cleaning the arp table all is gone ok. thnak you.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
Zyxel Community Virtual Assistant
