usg flex h new firmware 1.37
MassimoRiva
MassimoRiva Posts: 13 image  Freshman Member
First Comment Sixth Anniversary Nebula Gratitude
hi I've updated my devices in ha pro configurations and I had a problem on some services configured on them. there is anyone that had installed it and tested it?
thank you.
  • Zyxel_Barry
    Zyxel_Barry Posts: 119 image  Zyxel Community Virtual Assistant
    Hi @MassimoRiva,
    I understand you're experiencing issues with some services after updating your USG FLEX H series devices in an HA Pro configuration to firmware 1.37.
    When updating firmware on USG FLEX H series devices in an HA configuration, it's crucial that both devices are running the same firmware version. If there's a firmware mismatch, the HA pairing will show an error. The USG FLEX H series also has a configuration rollback feature for firmware versions 1.30 and above, which reverts to the previous working configuration if the new configuration fails to apply.
    To help us investigate this issue further, please provide the following information:
    • Device Models: Please specify the exact models of your USG FLEX H series devices.
    • Current Firmware Version: Confirm that both devices are currently running firmware version 1.37.
    • Detailed Problem Description: What specific services are experiencing problems? Can you describe the symptoms you are observing?
    • Network Topology: A diagram or description of your HA Pro setup, including how the devices are connected and the heartbeat port used.
    • Error Messages: Any error messages displayed on the device dashboard or in the event logs.
    • HA Status: The current HA status from System > Device HA > HA Status on the primary device.
    • Diagnostic Logs: If possible, please download the diagnostic logs from both devices by navigating to Maintenance > Diagnostics > Diagnostics in the web GUI and clicking "collect now."
    Additionally, if your devices are managed by Nebula, please enable Zyxel Support Access:
    • Go to Help > Support Request in the Nebula console.
    • Provide your Organization and Site name.
    Enabling Zyxel Support Access allows our support team to directly view your cloud environment configuration, which can significantly expedite the troubleshooting process.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,623 image  Zyxel Employee
    Hi @MassimoRiva
    Could you share what services have problem in details?
    Zyxel Melen
  • MassimoRiva
    hi, sorry for the delay; we have found the problem : the arp table of the device of our provider was dirty the access to our perimetral firewall was blocked/allowed and after cleaning the arp table all is gone ok. thnak you.
