good practice for setting up a wifi AP to access LAN ressource
hi
in office, we only use wired LAN
we have Wifi AP only for guests and employee's personnal devices. thi Wifi is on a specific ISP modem and no link with office's lan
i want to add a wifi AP for coworker when they are many in meeting room, because add a switch on the meeting desk is messy and laptop has no rj45 connection
what is the best pratice for ? create a specific SSID with only mac filtering (so the SSID is set top open ?)
i really don't know what is the best for…
Hi @Asgatlat
Please reference the items that Barry mentioned.
Key point:
- The SSID need to assign a VLAN ID.
- This SSID need to enable Layer 2 Isolation & Intra-BSS Traffic Blocking.
- Firewall need set security policy to block this VLAN access other interface/LAN/VLAN/Subnet.
Zyxel Melen0
Hi @Asgatlat,
To address your requirement for providing Wi-Fi access to coworkers in a meeting room for their laptops to access LAN resources, while maintaining security, here's a recommended approach:
Initial Solution
The best practice involves creating a dedicated SSID for your coworkers and implementing robust security measures beyond just MAC filtering, as MAC addresses can be spoofed. Integrating VLANs with your SSID will provide better network segregation.
- Create a Dedicated SSID:
- Set up a new SSID specifically for "Coworker Meeting Room" or similar.
- Implement Strong Security:
- WPA3-Personal or WPA2/WPA3-Mixed Mode: For robust security, use WPA3-Personal. If you have older devices that may not support WPA3, use WPA2/WPA3-Mixed mode. Avoid "Open" SSIDs, as they offer no encryption.
- (Optional) MAC-based Authentication (Whitelist): While not foolproof on its own, MAC-based authentication can add an additional layer of control. Configure a whitelist of MAC addresses for the devices your coworkers will use. This ensures only "known" devices can connect to this specific SSID.
- In Zyxel Nebula, you can often find this under MAC-based Authentication or Client Policy (MAC filter) features.
- For Zyxel firewalls with an AP Controller, you can use local MAC authentication.
- VLAN Segregation: This is crucial for isolating traffic.
- Assign this new SSID to a specific VLAN that is separate from your main corporate LAN.
- Configure your firewall or router to control access between this VLAN and your corporate LAN, allowing only necessary traffic (e.g., access to specific internal resources like printers or shared drives).
- This prevents unauthorized access to sensitive LAN resources from the Wi-Fi network.
- Enable Layer 2 Isolation & Intra-BSS Traffic Blocking: This feature prevents connected wireless clients on the same SSID from communicating directly with each other, enhancing security.
- Firewall Rules:
- On your firewall, create rules that specifically allow the necessary traffic from the coworker Wi-Fi VLAN to the specific LAN resources they need. Explicitly deny all other traffic from the Wi-Fi VLAN to the corporate LAN.
Information Collection Guide
To provide more tailored advice, please provide the following information:
- Zyxel Access Point Model(s): (e.g., NWA1123-ACv2, WAX610D, etc.)
- Firmware Version of the AP(s):
- Management Platform: Are your APs managed by Zyxel Nebula Cloud, a Zyxel Security Gateway (e.g., USG FLEX), or standalone?
- Network Topology (Diagram or Description): How is the new AP intended to connect to your existing network infrastructure?
- Specific LAN Resources: What exact LAN resources (e.g., file servers, internal websites, specific applications) do your coworkers need to access from this Wi-Fi?
- Nebula Specific Information (if applicable):
- Please enable Zyxel Support Access via
Help > Support Requestin your Nebula console. This allows our support team to view your cloud environment directly. - Provide your Organization Name and Site Name.
If you have feedback or idea about this AI assistant, share them in Community Feedback.0 - Create a Dedicated SSID:
Hi @Asgatlat
Key point:
Zyxel Melen0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
