NWA130BE - Firmware V7.30(2) breaks WDS
cseeg_zyxel
cseeg_zyxel Posts: 7 image  Freshman Member
We updated 3 NWA130BE wireless access points from V7.20(3) to V7.30(2) and WDS didn't work anymore. So we did a rollback to firmware V7.20(3) and everything works again.
Please fix this issue.
Best Answers
  • Zyxel_Tina
    Zyxel_Tina Posts: 729 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    Hi @cseeg_zyxel and all,
    Thank you for your config file. The issue you're experiencing is a known issue, and we plan to release an official firmware v7.30(3) in February to resolve it.
    As a workaround, we recommend downgrading to v7.20(3) for continued use. Alternatively, if using the current latest version v7.30(2), please avoid selecting "6GHz only" for WDS, as the 6 GHz band does not function as expected when used as a wireless uplink for Repeater.
    We'll keep you updated on the firmware release. Thank you for your understanding.
    Zyxel Tina
  • Zyxel_Tina
    Hi all,
    We would like to inform you that the updated firmware version has been released as planned. You may now proceed with upgrading to firmware version 7.30 Patch 3, which includes the fix for the previously identified 6 GHz uplink issue in Repeater mode.
    For your reference, please see the official article for the NWA130BE release notes, which documents the related fix.
    Zyxel Tina
  • wjwj
    wjwj Posts: 2 image  Freshman Member
    First Answer First Comment
    I can confirm that the updated firmware fixed the issue and works as expected.
  • cseeg_zyxel
    edited March 4 Answer ✓
    Thanks, everything works as expected. Firmware Update V7.30(3) fixed the issue.
  • Zyxel_Barry
    Zyxel_Barry Posts: 119 image  Zyxel Community Virtual Assistant
    Hi @cseeg_zyxel,
    We understand you're experiencing an issue with WDS functionality on your NWA130BE access points after upgrading from firmware V7.20(3) to V7.30(2), and that rolling back to V7.20(3) resolved the problem.
    A similar issue has been reported where the uplink interface goes down when configuring a WDS link between two NWA130BE APs after a firmware upgrade to version 7.20. While this report specifically mentions V7.20, it highlights that WDS issues can arise after firmware updates.
    To help us investigate this issue with V7.30(2) on your NWA130BE devices, please provide the following information:
    Initial Solutions:
    • Review WDS Configuration: Carefully re-verify your WDS configuration on both the Root AP and Repeater AP, ensuring that the WDS SSID and Pre-Shared Key are identical.
      • On the Root AP, set Radio 1 (5G band) OP Mode as "Root AP" and choose your WDS Profile.
      • On the Repeater AP, set Radio 1 OP Mode as "Repeater" and choose the same WDS Profile.
      • After configuration, disconnect the Ethernet cable from the Repeater AP and reboot it in its intended location.
    • Verify WDS Link Status:
      • On the Root AP, navigate to MONITOR > Wireless > WDS Downlink Info to check if the Repeater AP's MAC address is visible.
      • On the Repeater AP, go to MONITOR > Wireless > WDS Uplink Info to confirm if the Root AP's MAC address is displayed.
    • Check for Signal Strength: If you are unable to access the repeater AP after WDS mesh is set, it might be due to poor link signal strength.
    Information Collection Guide:
    To assist us further in diagnosing the problem, please provide the following:
    • Detailed Network Topology: A diagram or description of your network setup, including how the NWA130BE devices are connected (e.g., to a switch, directly to each other for WDS), and the IP addresses of your devices.
    • Screenshots:
      • Screenshots of the WDS configuration pages from both the Root and Repeater APs on firmware V7.30(2).
      • A screenshot of the MONITOR > Wireless > WDS Uplink Info page from the repeater AP when the uplink goes down on V7.30(2).
    • Diagnostic Information:
      • If your NWA130BEs are operating in standalone mode, please collect the diagnostic file after the issue occurs.
      • If your devices are managed in Nebula Cloud mode, please enable Zyxel Support access via Help > Support Request in the Nebula console and provide your Organization and Site name. This will allow our support team to view your cloud environment configuration directly, which can significantly expedite troubleshooting.
  • cseeg_zyxel
    We need support from a real person.
    We have configured 3 WAPs (NWA130BE) with WDS: 1 Root AP with Ethernet and 2 in Repeater Mode. We use the 6GHz Band. This works fine with firmware V7.20(3) but with version V7.30(2) this doesn't work at all. They can't connect to each other, even there is nothing in the logs regarding WDS. We also tried to reconfigure WDS and set the passwords again, rebooted the devices. Nothing helped.
    Please fix this firmware update.
  • Zyxel_Tina
    Hi @cseeg_zyxel,
    To help us investigate further, could you please share your startup-config file so we can reproduce the issue?
    Zyxel Tina
  • cseeg_zyxel
    Hello Tina, where should we upload the config file? Are there passwords and credentials stored in it? Please provide us a secure upload option.
    Thank you in advance
  • cseeg_zyxel
    Here are our config files from the WAPs. I deleted all sensitive data from the config files and replaced them with _REMOVED_. Hope this helps in investigating the problem.
  • wjwj
    I have exactly the same error. WDS is completely dead after the update. Please urgently revert and - hopefully - fix the faulty firmware.
  • Zyxel_Tina
    Zyxel Tina
  • Zyxel_Tina
    Hi all,
    Zyxel Tina
  • wjwj
  • cseeg_zyxel
