IPv6 with pppoe
bavaria
bavaria Posts: 32 image  Freshman Member
First Comment Friend Collector Seventh Anniversary
Hi
I have an USG100, and got from the ISP following addresses.
WAN: 2001.aaaa.b.cccc/64 and for LAN: 2001.aaaa.dddd/48
If I configure only the wan1_ppp with SLAAC, I get a valid ip and I can ping6 within the USG diagnostic as long the LAN interface is inactive.
But if I activate the LAN interface the ping6 shows 'Destination unreachable: Address unreachable'.
I tried different WAN/LAN configurations, but none is working.
any ideas?
regard
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,623 image  Zyxel Employee
    Hi @bavaria
    1. Could you share the ISP IPv6 information and your firewall's start-up config file for us to check? Please share it in a private message with me.
    2. May I know if the LAN device can pass the IPv6 test?
    Zyxel Melen
  • Zyxel_Melen
    Update:
    Issue solved by remote configuration.
    Zyxel Melen
