Remote vpn and mfa
We made a Remote access VPN connection for the customer using the native Windows VPN client.
We also put a VPN on top of MFA.
MFA only supports local users.
The user needs Google Authenticator to use it.
Is the only way to get the user a QR code for the authenticator, that
the user logs in inside the firewall and scans the code there and enters
the verification code?
Hi @MarkoK
Yes, to enable two factor for local user, you need to access to the firewall's GUI.
Additionally, there has an alternate way for two factor:
💡Duo Security Authentication Integration Guide — Zyxel Community
You may reference the post above first.
Zyxel Melen0
Hi @MarkoK,
Thank you for reaching out to the Zyxel Community. I understand you're looking to configure Google Authenticator for MFA with your Remote Access VPN using a native Windows VPN client on your USG FLEX H Series.
Yes, the process you described is the correct way to enroll a local user for Google Authenticator with your USG FLEX H Series firewall. The user needs to access the firewall's web interface to scan a QR code.
Here's a step-by-step guide:
Enable Google Authentication for a User:
- Navigate to
User & Authentication>User/Groupin the firewall's web interface. - Select the local user account that requires Two-Factor Authentication (2FA).
- Enable the
Two-Factor Authenticationoption. - Click "Set up Google Authenticator" to begin the configuration.
- Navigate to
Set Up Google Authenticator on the User's Mobile Device:
- The user needs to download and install the Google Authenticator app on their mobile device.
- Open the Google Authenticator app and scan the QR code displayed on the firewall's web GUI.
- The app will generate a time-based one-time password (TOTP).
- Enter the token code shown on the app into the designated field on the web GUI and click "Verify Code and Finish."
- After successful registration, backup codes will be displayed. Ensure the user downloads and stores these securely.
Configure VPN Types for 2FA:
- Navigate to
User & Authentication>Authenticationin the firewall's web interface. - Enable two-factor authentication for IPsec VPN.
- Set the
Valid Time, which specifies the time limit for entering the 2FA code. - Select the VPN types (e.g., Remote Access VPN) requiring 2FA.
- Navigate to
When the user connects to the VPN, they will enter their username and password, and then be redirected to a portal to enter the six-digit code generated by their Google Authenticator app.
To assist you further, please provide the following information:
- Device Model: (e.g., USG FLEX 100H, USG FLEX 200H)
- Firmware Version:
- Screenshots: If you encounter any error messages during the setup process, please provide screenshots.
If you have feedback or idea about this AI assistant, share them in Community Feedback.0 -
Hi @MarkoK
Zyxel Melen0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 485 News and Release
