Support FQDN wildcard for both root domain and subdomains on USG FLEX H
Currently on uOS, the FQDN object only supports the format *.domain.com, which matches subdomains (e.g., www.domain.com, mail.domain.com) but does not include the root domain (domain.com).
In ZLD systems, the format *domain.com was supported, allowing both the root domain and subdomains to be covered by a single entry.
User @PeterUK would like to request an enhancement to bring this behavior to uOS, so that a single wildcard can cover both the root domain and its subdomains.
This suggestion originated from the post found here: FQDN problem www.grc.com vs grc.com under wildcard — Zyxel Community
If anyone likes this idea, please show your support by leaving a comment or voting for it.
Zyxel Tina
Not sure it is complicated to create an FQDN object group and have the subdomain wildcard + root domain in the group.
Hi Zulgrib
The problem is if you have many FQDN like I do one problem is you don't know if you need both subdomain wildcard + root domain the other problem is there is a limited number of address objects you can make meaning if you have to do subdomain wildcard + root domain this take up two objects and not one.
- 217 Nebula Ideas
- 583 USG FLEX H Series
- 297 Service & License
- 476 News and Release
