1.37 uOS - errors when you set DHCP table from Nebula
GiuseppeR
GiuseppeR Posts: 644 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula First Comment Friend Collector
Hello everyone,
I was testing new firmware to deploy in production.
As you set DHCP table on Nebula:
While if you log in to your firewall and set it from there everything is smooth:
Why I cannot set the DHCP reservation from Nebula?
  • Zyxel_Barry
    Zyxel_Barry Posts: 120 image  Zyxel Community Virtual Assistant
    Hi @GiuseppeR,
    Thank you for reaching out to the Zyxel Community regarding the DHCP reservation issue on your USG FLEX H Series device managed by Nebula.
    The error message "IP address is incorrect format" when setting the DHCP table from Nebula suggests a potential discrepancy or formatting requirement in the Nebula interface. While the local GUI allows for seamless configuration, Nebula may have specific input validation.
    Here's a guide to help you troubleshoot and resolve this:
    • Review Nebula DHCP Configuration for USG FLEX H Series:
      • Navigate to Site-wide > Configure > Firewall > Port & Interface in your Nebula console. This is where you configure static DHCP clients directly from the interface page for USG FLEX H Series.
      • Carefully examine the format of the IP addresses you are trying to reserve. Ensure there are no leading/trailing spaces or invalid characters.
      • Verify that the IP addresses you are trying to reserve fall within the defined DHCP pool for that interface.
    • Verify Firmware and Nebula Compatibility:
      • Ensure your USG FLEX H Series firmware (uOS) and Nebula Control Center are running compatible and up-to-date versions. Nebula 18.30 introduced cloud configuration management and synchronization for H Series firewalls, and updates often include specific behaviors for configuration synchronization.
      • Check for any known issues or release notes related to DHCP reservations for your specific firmware version on USG FLEX H Series in conjunction with Nebula.
    • Utilize Local GUI for Verification (if still an issue):
      • Although the goal is to configure via Nebula, temporarily setting a DHCP reservation via the local GUI (Network Status > DHCP Table) and then observing how Nebula reflects or attempts to synchronize it can provide insight into potential conflicts or formatting differences.
    To further investigate, please provide the following information:
    • Nebula Organization and Site Name: This will allow our support team to directly view your cloud environment configuration and expedite troubleshooting.
    • Firmware Version: The exact firmware version (e.g., 1.37 uOS) running on your USG FLEX H Series.
    • Screenshots: If the error message in Nebula provides more details or if there are other relevant error messages in the Nebula event logs, please include screenshots.
    • Network Topology: A brief description or diagram of your network setup.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,532 image  Zyxel Employee
    Hi @GiuseppeR
    This is a known issue on Nebula. It will be fixed this Tuesday.
    Zyxel Melen
  • Zyxel_Melen
    edited January 29
    Update:
    The issue is fixed on 2026/1/27.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    thanks for the update
