1.37 uOS - Clicking on Security Policy does not save NAT rule
GiuseppeR
GiuseppeR Posts: 664 image  Master Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
Hello everyone,
when you set a new NAT rule and you click on Security Policy:
the system does not ask you if you want to save or not the new rule you just edit, so you go to Security Policy area losing the NAT rule. It should be better to have a popup menu asking you if you want to save the new rule.
If you click on Apply:
the system saves it but you have to go manually to Security Policy area to add the rule to let someone else to enter that server port.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,623 image  Zyxel Employee
    Hi @GiuseppeR
    The security policy hyperlink only takes you to the security policy page, it won't generate related security policy. You need manually add the security policy.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    yes, you are right.
    But when I write a rule entering values in its fields, the page should suggest to save that new rule before leaving that page.
  • Zyxel_Melen
    Hi @GiuseppeR
    Thanks for the suggestion, we currently have this hint.
    When you add a security policy, the edit page will ask you if you want to apply it or not.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    exactly like that, but it should be an alert like that also when setting a NAT rule and then clicking on Security Policy.
    In this way it should be easier to create before the NAT rule and then the Security Policy to let that rule to work properly
