1.37 uOS - errors when you set DHCP table from Nebula
Hello everyone,
I was testing new firmware to deploy in production.
As you set DHCP table on Nebula:
While if you log in to your firewall and set it from there everything is smooth:
Why I cannot set the DHCP reservation from Nebula?
Hi @GiuseppeR,
Thank you for reaching out to the Zyxel Community regarding the DHCP reservation issue on your USG FLEX H Series device managed by Nebula.
The error message "IP address is incorrect format" when setting the DHCP table from Nebula suggests a potential discrepancy or formatting requirement in the Nebula interface. While the local GUI allows for seamless configuration, Nebula may have specific input validation.
Here's a guide to help you troubleshoot and resolve this:
Review Nebula DHCP Configuration for USG FLEX H Series:
- Navigate to
Site-wide > Configure > Firewall > Port & Interfacein your Nebula console. This is where you configure static DHCP clients directly from the interface page for USG FLEX H Series. - Carefully examine the format of the IP addresses you are trying to reserve. Ensure there are no leading/trailing spaces or invalid characters.
- Verify that the IP addresses you are trying to reserve fall within the defined DHCP pool for that interface.
- Navigate to
Verify Firmware and Nebula Compatibility:
- Ensure your USG FLEX H Series firmware (uOS) and Nebula Control Center are running compatible and up-to-date versions. Nebula 18.30 introduced cloud configuration management and synchronization for H Series firewalls, and updates often include specific behaviors for configuration synchronization.
- Check for any known issues or release notes related to DHCP reservations for your specific firmware version on USG FLEX H Series in conjunction with Nebula.
Utilize Local GUI for Verification (if still an issue):
- Although the goal is to configure via Nebula, temporarily setting a DHCP reservation via the local GUI (
Network Status > DHCP Table) and then observing how Nebula reflects or attempts to synchronize it can provide insight into potential conflicts or formatting differences.
To further investigate, please provide the following information:
- Nebula Organization and Site Name: This will allow our support team to directly view your cloud environment configuration and expedite troubleshooting.
- Firmware Version: The exact firmware version (e.g., 1.37 uOS) running on your USG FLEX H Series.
- Screenshots: If the error message in Nebula provides more details or if there are other relevant error messages in the Nebula event logs, please include screenshots.
- Network Topology: A brief description or diagram of your network setup.
If you have feedback or idea about this AI assistant, share them in Community Feedback.0 -
Update:
The issue is fixed on 2026/1/27.
Zyxel Melen0 -
Hi @Zyxel_Melen
thanks for the update
- 588 USG FLEX H Series
- 477 News and Release
Zyxel Community Virtual Assistant
