AES_GCM on ATP-Series
Tunox
Tunox Posts: 4 image  Freshman Member
Dear Zyxel-Team,
in the near Future a Phone-Provider we have an VPN Connection to, tolds me in December, that we urgently should update our Connection from AES_CBC to AES_GCM.
We use a ATP700 with the latest Update installed (5.41). Is there a Chance, that Zyxel provides GCM in an further Update ?
Thx
Gordon
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,680 image  Zyxel Employee
    Hi @Tunox
    After checking with our product team, the ATP series, also USG FLEX series, won't implement AES_GCM.
    If you have this requirement, we recommend migrating to USG FLEX H series.
    https://www.zyxel.com/global/en/products/next-gen-firewall/usg-flex-firewall-usg-flex-700h
    Zyxel Melen
  • mMontana
    mMontana Posts: 1,469 image  Guru Member
    Is available the technical reason why AES-GCM won't be implemented, as cypher, on Flex series?
  • Zyxel_Melen
    Hi @mMontana
    For ZLD (USG FLEX/ATP), we are not able to add AES-GCM-256 support, due to the fact that the underlying VPN turnkey does NOT support the algorithm and migrating to a newer version turnkey is not an option on this platform.
    Zyxel Melen
  • mMontana
    …because the updated version of turnkey is available on newer devices, Flex H.
    I hope there won't be from third parties (like PCI-DSS) a "ban" for device having only AES_CBC as available protocol.
    Could hit some nerve at budget levels…
