Remote vpn and mfa
MarkoK
MarkoK Posts: 5 image  Freshman Member
We made a Remote access VPN connection for the customer using the native Windows VPN client.
We also put a VPN on top of MFA.
MFA only supports local users.
The user needs Google Authenticator to use it.
Is the only way to get the user a QR code for the authenticator, that
the user logs in inside the firewall and scans the code there and enters
the verification code?
  • Zyxel_Barry
    Zyxel_Barry Posts: 119 image  Zyxel Community Virtual Assistant
    Hi @MarkoK,
    Thank you for reaching out to the Zyxel Community. I understand you're looking to configure Google Authenticator for MFA with your Remote Access VPN using a native Windows VPN client on your USG FLEX H Series.
    Yes, the process you described is the correct way to enroll a local user for Google Authenticator with your USG FLEX H Series firewall. The user needs to access the firewall's web interface to scan a QR code.
    Here's a step-by-step guide:
    • Enable Google Authentication for a User:
      • Navigate to User & Authentication > User/Group in the firewall's web interface.
      • Select the local user account that requires Two-Factor Authentication (2FA).
      • Enable the Two-Factor Authentication option.
      • Click "Set up Google Authenticator" to begin the configuration.
    • Set Up Google Authenticator on the User's Mobile Device:
      • The user needs to download and install the Google Authenticator app on their mobile device.
      • Open the Google Authenticator app and scan the QR code displayed on the firewall's web GUI.
      • The app will generate a time-based one-time password (TOTP).
      • Enter the token code shown on the app into the designated field on the web GUI and click "Verify Code and Finish."
      • After successful registration, backup codes will be displayed. Ensure the user downloads and stores these securely.
    • Configure VPN Types for 2FA:
      • Navigate to User & Authentication > Authentication in the firewall's web interface.
      • Enable two-factor authentication for IPsec VPN.
      • Set the Valid Time, which specifies the time limit for entering the 2FA code.
      • Select the VPN types (e.g., Remote Access VPN) requiring 2FA.
    When the user connects to the VPN, they will enter their username and password, and then be redirected to a portal to enter the six-digit code generated by their Google Authenticator app.
    To assist you further, please provide the following information:
    • Device Model: (e.g., USG FLEX 100H, USG FLEX 200H)
    • Firmware Version:
    • Screenshots: If you encounter any error messages during the setup process, please provide screenshots.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,623 image  Zyxel Employee
    edited February 13 Answer ✓
    Hi @MarkoK
    Yes, to enable two factor for local user, you need to access to the firewall's GUI.
    Additionally, there has an alternate way for two factor:
    💡Duo Security Authentication Integration Guide — Zyxel Community
    You may reference the post above first.
    Zyxel Melen
