AES_GCM on ATP-Series
Dear Zyxel-Team,
in the near Future a Phone-Provider we have an VPN Connection to, tolds me in December, that we urgently should update our Connection from AES_CBC to AES_GCM.
We use a ATP700 with the latest Update installed (5.41). Is there a Chance, that Zyxel provides GCM in an further Update ?
Thx
Gordon
Hi @Tunox
After checking with our product team, the ATP series, also USG FLEX series, won't implement AES_GCM.
If you have this requirement, we recommend migrating to USG FLEX H series.
Zyxel Melen0
Hi @Tunox
Zyxel Melen0 -
Is available the technical reason why AES-GCM won't be implemented, as cypher, on Flex series?
Hi @mMontana
For ZLD (USG FLEX/ATP), we are not able to add AES-GCM-256 support, due to the fact that the underlying VPN turnkey does NOT support the algorithm and migrating to a newer version turnkey is not an option on this platform.
Zyxel Melen0 -
…because the updated version of turnkey is available on newer devices, Flex H.
I hope there won't be from third parties (like PCI-DSS) a "ban" for device having only AES_CBC as available protocol.
Could hit some nerve at budget levels…0
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
