USG FLEX 500 H V1.37(ABZH.0)
I'm looking for the CLI command to create a new interface ge5 for example ?
I'm also looking for the CLI command to remove a port (p10) from interface ge4
and finally, I'm also looking for the commande to remove an existing interface, for example ge2.
I looked at this guide : https://download.zyxel.com/USG_FLEX_500H/cli_reference_guide/USG%20FLEX%20500H_V1.36.pdf
Thanks a lot for your help.
Best regards
Hi @sysco
Type in "vrf main interface ethernet/vlan <interface name> <default-snat / ping-check / ipv4 / ipv6 / network-stack / ethernet / enabled / type / ports>"
Start with del to remove any config, includes port in an interface. Example: "del vrf main interface ethernet ge4 ports p10"
I suggest to remove it from GUI since you need to delete it reference. From GUI you can check which object/policy/settings relates with it.
Zyxel Melen0 -
Thanks for your help.
I tried this command but it doesn't work :
/ vrf "main" interface ethernet "lan1"
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
