zyxel gs1900-24E configuration issues
Hi, am little no-vice coming to switches so bear with me if I am asking simple questions. I have configured this switch to pass thru internet to get hang of it. but at any point of time I see there are only 2 ports lightening up and no other wires connected to them light up.
Here is the case, I have 3 rooms where I have ethernet wall jacks. I connected all wires in my network room to the switch and port 1 to internet modem. 2 rooms I have wired connection but third room I do not have internet.
Hi @netRK
- Please help to check the config > Port if the connecting ports are set disable/down first.
- If they are all enable, please help to do some hardware cross check.
- Directly connect the device/bypass the ethernet wall jack to test.
- Move the working port to the issue port to check this switch port having issue or not.
- Move the issue port to the working port to check if this will work.
- Swap the connecting devices between the working part and issue part.
- If your configuration enables loop guard, please check if there any ports is in err-disable/loop status.
Hope these helps.
Zyxel Melen0
Hi @netRK
Hope these helps.
Zyxel Melen0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
