IPSec VPN Site-to-Site behind router
Hello sir or madame, this is my problem. I have 3 buildings with 3 distinct types of connection:
- [home]#A
- Router#A FRITZ!Box 4040 (OS 08.03) connected to ONT
- Router#1 - IP 192.168.198.60
- DHCP server
- Local Area Network 192.168.198.0/24
- FTTH connection
- [company]#B
- Router#B FRITZ!Box 7560 (OS 07.30) connected to ONT
- IP 192.168.199.70
- No DHCP server because there is a domain controller
- Local Network 192.168.199.0/24
- FTTH connection with static Public IP
- [house] #C
- Router#C FRITZ!Box 6850LTE (OS 08.20) connected to LTE
- IP 192.168.201.1
- DHCP server
- Local Network 192.168.201.0/24
- LTE connection
- Cascaded Zyxel USG FLEX 50H Firewall (uOS 1.37)
- WAN side – IP 192.168.201.2 – Gateway 192.168.201.1
- LAN side – IP 192.168.200.2 – Local Area Network 192.168.200.0/24
I would like to create 2 VPN tunnels between #A↔B (Villa_Barbiano) and between #C↔B (Villa_Bizzuno). I have already did several attempts, even with my IT system engineer, but we are faced with some connection problems
- Tunnel Case #A↔B (Villa_Barbiano)
- Router#B
- Internet Interface → VPN → Permissions.
- Add VPN connection.
- Connect this FRITZ!Box with a corporate VPN.
- Put all the settings referenced on the help page, including *.myfritz.net addresses.
- Confirmed and then restarted the router.
- Router#A
- Internet → VPN → Enable (IPSec).
- Connect your local network with another FRITZ!Box (LAN-LAN pairing).
- Router#B
This tunnel seems OK and stable for now, so the 192.168.198.0/24 LAN network is accessible and scannable.
- Tunnel Test Case #C↔B (Villa_Bizzuno_test)
- Router#B
- Router#C
- Internet Interface → VPN → Enable (IPSec).
- Router#B
This tunnel seems OK and stable for now, so the 192.168.201.0/24 LAN network is accessible and scannable and I did this test in order to understand if the LTE operator hides with NAT the connection.Obviously, the network 192.168.200.0/24 is not reachable (because in another mask protected by the firewall); consequently, in order to connect the 2 LANs, the only way is that the tunnel VPN_IPSec takes place between Router#B and the Firewall, according to the site-to-site logic IPSec_VPN IKEv1.
- Tunnel Test Case #C↔B (Villa_Bizzuno)
- Router#B
- Connect this FRITZ!Box with a corporate VPN.:
- VPN username (Key-ID): yzaygo79jtldsmgy.myfritz.net
- VPN (Preshared Key) Password: My Password
- Remote Station Internet Address: yzaygo79jtldsmgy.myfritz.net
- Internet address of this FRITZ!Box: 185.240.71.33
- Remote Network: 192.168.200.0
- Subnet Mask: 255.255.255.0
- Maintain VPN connection constantly: Yes
- Allow NetBIOS over this connection (for Microsoft Windows file shares and printers): Yes
- Router#B
Moving now to the firewall interface, I detail the custom settings of the device for the configuration of the VPN, using the parameters of Phase1 and Phase2 "stolen from the Villa_Barbiano tunnel" and from the LAN-LAN VPN used as a test between the 7560 and the 6850LTE:
[VPN Villa_Barbiano tunnel / IKE SA: DH2 / AES-256 / SHA1 / IPsec SA: ESP-AES-256 / SHA2-512 / LT-3600]
[VPN tunnel Villa_Bizzuno_test / IKE SA: DH2/AES-256/SHA512/IPsec SA: ESP-AES-256/SHA2-512/LT-3600]
- General Setting:
- Description: Villa
- IKE Version: IKEv1
- Type: Policy-based
- Network
- My Address: IP 192.168.201.2 (Firewall WAN side identifier)
- Peer Gateway Address: 185.240.71.33 (Public IP of Router#B)
- Fallback: OFF
- Zones: IPSec_VPN
- Authentication (Pre-Shared Key): My password
- Advanced Setting:
- Local ID: yzaygo79jtldsmgy.myfritz.net
[VPN username (Key-ID) set to 7560] - Remote ID: 185.240.71.33
- Advanced Setting:
- Phase 1 Settings
- SA Life Time: 28800
- Proposal Encryption: AES256
- Proposal Authentication: SHA1
- Diffie-Hellman Groups: DH2
- Advanced Setting:
- DPD Delay: 5
- UDP Encapsulation: ON
(according to the technical literature it is the setting necessary to force passage over port UDP4500)
- Phase 2 Settings
- Initiation: Nailed-up
- Policy:
- Local LAN: 192.168.200.0/24
- Remote LAN: 192.168.199.0/24
- SA Life Time: 3600
- Proposal Authentication: SHA512
- Perfect Forward Secrecy (PFS): OFF
- Destination (the first Remote policy) and NAT Rule: OFF
Still on technical literature (I don't know if official or not) he strongly advises us that:
- in Router#C – FRITZ! Box 6850LTE (OS 08.20) – the "Firewall" device is enabled as an "Exposed Host" (setting done);
- the FRITZ! OS 08.20 does not handle this setting well and it is recommended to enable the individual UDP500 and UDP4500 ports anyway (setting done);
- it is necessary to disable the NetBIOS and Telendo filters of the Router#C – FRITZ! Box 6850LTE (setup done);
This tunnel does NOT open, so I forward the following:
- Router#B side:
- the green VPN status light is off and the LAN 192.168.200.0/24 is not accessible and scannable.
- From the event log under the system menu, nothing interesting can be deduced.
- Router Side#C:
- Firewall side cascading to Router#C
- Export Attachment
I look forward to your consideration, thanks.
Hi @Olympus
- From Router B log, I can't find any info for VPN connection Villa_Bizzuno.
- From Router C log, I can find the USG FLEX H tried to connect VPN, but there's no response from site B.
Therefore, it seems like site C FRITZ!Box didn't allow and set NAT rule for VPN protocols. Please ensure these are allow and set NAT rule on your site C FRITZ!Box:
UDP port 500 (ISAKMP)- UDP port 4500 (NAT traversal)
- ESP ("Encapsulated Security Payload", IP protocol number 50)
Hope this helps.
Zyxel Melen0
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
