USG FLEX 500 - DNS white list doesn't work over the DNS general classification
GateArray
GateArray Posts: 10 image  Freshman Member
First Answer First Comment Friend Collector Sixth Anniversary
Ciao
I got a problem regarding wrong DNS classification.
A site of a customer as been classified as "phishing".
I put that dns on "DNS ALLOW LIST" section, but the block persist.
if i try the make a simple "ping" this is the FW response:
It seems that "DNS ALLOW LIST" is working properly.
USG FLEX 500
5.41(ABUJ.0) 2025-09
Any idea?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,622 image  Zyxel Employee
    Hi @GateArray
    Thos domain is classified as business.
    Now, you should be able to access without issue.
    Zyxel Melen
    PeterUK Posts: 4,426 image  Guru Member
    edited January 31
    Try the following by SSH or web console
    ip dns server cache-flush
    debug content-filter https-domain-filter cache flush
    There is a DNS flush you can try in monitor > security Statistics > DNS content filter
  • Zyxel_Melen
    Hi @GateArray
    Zyxel Melen
