USG FLEX 500 H V1.37(ABZH.0)
sysco
sysco Posts: 3 image  Freshman Member
First Comment Sixth Anniversary
I'm looking for the CLI command to create a new interface ge5 for example ?
I'm also looking for the CLI command to remove a port (p10) from interface ge4
and finally, I'm also looking for the commande to remove an existing interface, for example ge2.
I looked at this guide : https://download.zyxel.com/USG_FLEX_500H/cli_reference_guide/USG%20FLEX%20500H_V1.36.pdf
Thanks a lot for your help.
Best regards
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,680 image  Zyxel Employee
    Hi @sysco
    Type in "vrf main interface ethernet/vlan <interface name> <default-snat / ping-check / ipv4 / ipv6 / network-stack / ethernet / enabled / type / ports>"
    Start with del to remove any config, includes port in an interface. Example: "del vrf main interface ethernet ge4 ports p10"
    I suggest to remove it from GUI since you need to delete it reference. From GUI you can check which object/policy/settings relates with it.
    Zyxel Melen
  • sysco
    Thanks for your help.
    I tried this command but it doesn't work :
    / vrf "main" interface ethernet "lan1"
