ATP200: no connection to gateway after automatic Firmware update (V5.41 to V5.42)
wguenten
wguenten Posts: 6 image  Freshman Member
ATP200
Automatic Update from V5.41(ABFW.0) to V5.42(ABFW.0). Status OK.
But no connection to gateway is possible (fixed addresses ipv4 and ipv6).
After reboot with V5.41 the connection runs correctly.
  • wguenten
    Rebooting again with V5.42 → works correctly. Problem solved.
  • wguenten
  • wguenten
    The problem is not solved:
    After a reboot with V5.42 the atp200 runs some time correctly. After a certain time (hours) the problem begins again.
    One app (cnlab) pointed to a DNS problem.
    After some reboots and one unexpected reboot: I go back to V5.41 and wait until a correct update is available.
    PeterUK Posts: 4,451 image  Guru Member
    Do you have FQDN objects?
    https://community.zyxel.com/en/discussion/32312/v5-42-dns-is-broken-with-fqdn-objects#latest
  • wguenten
    Yes, I habe several FQDN objetcts, as well ipv4 and ipv6.
  • wguenten
    With updating to V5.42(ABFW.1) my problem is solved.
