Dial Remote VPN from internal network
Matthew
Matthew Posts: 24 image  Freshman Member
First Comment First Answer Friend Collector Eighth Anniversary
How can I get Remote VPN to work from a local network? I have users with laptops that dial remotely and it works fine. Sometimes they bring their personal laptops into the office and connect to the guest network. Rather than set up specific DMZ/low trust type wifi network, I'd like for them to be able to dial the VPN from the guest network.
    PeterUK Posts: 4,451 image  Guru Member
    How I have done it is to do the following:
    VPN Server Address
    type = IP address
    IP address = 0.0.0.0
    NAT Traversal = custom IP or Domain Name then add your Domain Name may not work by IP
    Then your LAN DNS point your Domain Name to your LAN gateway IP so that when the users lookup you Domain Name they connect locally and Remote for your  Domain Name points your WAN IP.
