V5.42 DNS is broken with FQDN objects
FLEX200 V5.42
If you have no FQDN objects you may likely not see a problem but if you do big problem as some DNS lookups will fail completely to pass through the USG no matter how many times you try.
Here it my bind and then DNS by 8.8.8.8
and this is a Wireshark view WAN side
Hi @PeterUK
It seems like the issue that Alex encountered. Let me provide you a date code firmware.
Zyxel Melen0
Same situation.
Yesterday i got ticket from our user, that don't work 1 site.
DNS servers don't resolv it. Only it in this domain.
[root@docker ~]# nslookup lsul.nalog.ru 46.61.250.141
Server: 46.61.250.141
Address: 46.61.250.141#53Non-authoritative answer:
*** Can't find lsul.nalog.ru: No answer[root@docker ~]# nslookup lkul.nalog.ru 46.61.250.141
;; connection timed out; no servers could be reached[root@docker ~]# nslookup nalog.ru 46.61.250.141
Address: 37.220.164.100Zyxel, please, forgive your users! Make 1 stable FW for your devices.
Hi @PeterUK
Zyxel Melen0 -
The same problem is the resolution of some names on the internal DNS server by servers located in the DMZ Zywall USG Flex 200 V5.42(ABUI.0). Timeout...
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
