ipsec vpn
Franky_Bettazz
Franky_Bettazz Posts: 2 image  Freshman Member
i have 2 usg flex
I configured a VPN with Wizard and I get the error: Command failed: establishing CHILD_SA 'xxxx_sp1' failedThe routers are open with a static IP.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,680 image  Zyxel Employee
    Hi @Franky_Bettazz
    May you share:
    1. Where did you get this error message? From event log or after the Wizard setup?
    2. If is from the event log, could you share other logs with us?
    3. If is after the Wizard setup, please help to record a video from starting setup with Wizard. This allows us to investigate this issue.
    Zyxel Melen
