ATP200: no connection to gateway after automatic Firmware update (V5.41 to V5.42)
Rebooting again with V5.42 → works correctly. Problem solved.
The problem is not solved:
After a reboot with V5.42 the atp200 runs some time correctly. After a certain time (hours) the problem begins again.
One app (cnlab) pointed to a DNS problem.
After some reboots and one unexpected reboot: I go back to V5.41 and wait until a correct update is available.
Do you have FQDN objects?
https://community.zyxel.com/en/discussion/32312/v5-42-dns-is-broken-with-fqdn-objects#latest
Yes, I habe several FQDN objetcts, as well ipv4 and ipv6.
With updating to V5.42(ABFW.1) my problem is solved.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
