configuring remote access vpn
Dpj
When i try to configure an remote access vpn, i get this error:
There were errors saving this configuration.
- ERR_LOCAL_CERTIFICATE_NAME_UNEXIST
any ideas?
I think I remember having a similar issue before. Have you tried creating a new self-signed certificate for the VPN?
- Go to System > Certificate > Add
- Name the certificate something… I normally just name it RemoteAccess_VPN
- Update the following values, leave all other settings as default
- Enter the Host IP Address/Domain Name. This should be, or resolve to, the Public IP of the interface the VPN is configured on.
- Extended Key Usage —> Server Authentication
- Lifetimes —> 10 year (I think this is optional).
- Then, select this certificate from VPN > IPSec VPN > Remote Access VPN > Certificate for VPN Validation > Manual
That always fixed it for me.
In most cases, once you create and save the manual certificate, the firewall will accept it. After that, you can switch Certificate Validation back to Auto, and the USG will automatically generate a new certificate for you.
Hope that helps!
seems working! thx
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
