NWA50AX PRO - How Do I Seperate Signals
Nakatomi_Uk
in Wireless
Good evening
I have the NWA50AX PRO in standalone mode with default 2.4ghz and 5ghz under one SSID name how do I seperate them into each please
In the SSID you do this
Then on the AP management page you select the given SSID to the Radio
Thank you for your answer I have a lot of default profiles called WIZ_SSID_ numbers at the end can I delete those
It wont let me edit the profile name under SSID Summary either
Yes you should be able to delete them if all object references are removed
It wont let me oddly and when I create my own SSID name it doesnt show up in the drop down list of Radio Profile just the one thats default
reset to factory and don't use the wizard
Okay so reset it and then log in via a browser on PC and do it that way
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
