NWA50AX PRO - How Do I Seperate Signals
Nakatomi_Uk
Nakatomi_Uk Posts: 7 image  Freshman Member
Good evening
I have the NWA50AX PRO in standalone mode with default 2.4ghz and 5ghz under one SSID name how do I seperate them into each please
    PeterUK Posts: 4,451 image  Guru Member
    In the SSID you do this
    Then on the AP management page you select the given SSID to the Radio
  • Nakatomi_Uk
    edited February 19
    Thank you for your answer I have a lot of default profiles called WIZ_SSID_ numbers at the end can I delete those
    It wont let me edit the profile name under SSID Summary either
    edited February 19
    Yes you should be able to delete them if all object references are removed
  • Nakatomi_Uk
    It wont let me oddly and when I create my own SSID name it doesnt show up in the drop down list of Radio Profile just the one thats default
    reset to factory and don't use the wizard
  • Nakatomi_Uk
    Okay so reset it and then log in via a browser on PC and do it that way
