Firewall Configuration Converter fails with ZyWALL 110 (V4.73(AAAA.2))
Rimfire
Rimfire Posts: 20 image  Freshman Member
Hi
Tested with two or three 110s and with all of them the converters refuses to Load the source conf. My plan is first convert to VPN100 and then from VPN100 to USG Flex 200H.
This tool:
Firewall Configuration Converter | Zyxel Networks
The error message:
"The file is mismatched with tool, please upload a ZyWALL110 (4.32 or later) configuration file."
Any ideas?
There are several ZyWALL 110s needed to replace to Flex 200Hs. Some of them have pretty complex configuration, so the plan is to stick OnPrem / Local configuration.
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,683 image  Zyxel Employee
    edited February 23
    Hi @Rimfire
    Could you share the configuration file with me? So we can help to generate the configuration file for USG FLEX 200H for you.
    I will send you a private message for the configuration file.
    Zyxel Melen
  • Zyxel_Melen
    Update:
    If any user encounter the same issue, please remove the first four line of the configuration file, which leads the convertor incorrect recognize the config file.
    Zyxel Melen
