GS1900-24EP get MAC of device connected to switch port
Hi @IronKalli
Thanks for sharing the screenshot.
May I check some details?
- What device is connecting on this port?
- Since MAC address entry has an aging time, 300 seconds, could you help to check if the device has any traffic when you can't find the MAC address on the MAC table?
- Can you find any MAC address for this port without filter?
About the firmware upgrade, since the later firmware versions (after V2.80 patch 1) didn't encounter this issue, I'm unsure if the issue been fixed after firmware upgrade. You may give it a try.
Zyxel Melen0
Use any third party SNMP tool to query your GS1900 with this standard OID .1.3.6.1.2.1.2.2.1.6, so you don't need to calculate the MAC address range by yourself.
Hi @IronKalli
I check my GS1900 with latest firmware version, and I can check the MAC table by all and specific port. Path: Menu > Monitor > Mac table.
Could you share how did you filter? If possible, please record a video. Also, what's your device's firmware version?
Zyxel Melen0 -
Hi
thanks for your answer.
My problem seems to be device related.
It normally wokrs to see the MAC of any port as you described.
But with some (a bit special) devices the MAC is not shown, even though the port is up
Here is the firmware and port 9 shown
But the MAC filter definitely does not show any entry
I don't know what's happening here, but it is a phenomen which only shows with my special devices
Do you think there is a firmware update I should try?
Thanks and regards
Kalli
Hi @IronKalli
Zyxel Melen0 -
The connecting device is a Laser Line Triangulation scanner 'scanCONTROL 2900' manufactured by company microepsilon
And you are right again, it is related to the traffic (the scanner had no traffic for quite a long period)
When I connect to the device and produce some traffic, I am able to see it in the MAC table of the GS1900
It disappears after a while, but is coming back when I produce traffic againSorry, I had no knowledge of the aging time
But now I know how to handle and have everything I needThanks a lot for your help
Kalli1
- 220 Nebula Ideas
- 605 USG FLEX H Series
- 482 News and Release
