Zywall USG FLEX Series & ATP Series - V5.42Patch 1 Firmware Release
Zyxel_Melen
Zyxel_Melen Posts: 4,616 image  Zyxel Employee
Zywall USG FLEX Series & ATP Series Release Note
February 2026
Firmware Version on all models
(Click the hyperlink to find the firmware file directly)
FLEX SeriesDownload linkATP SeriesDownload link
FLEX50/USG20-VPNV5.42(ABAQ.1)C0ATP100V5.42(ABPS.1)C0
FLEX50W/USG20W-VPNV5.42(ABAR.1)C0ATP100WV5.42(ABRW.1)C0
FLEX50AXV5.42(ACGB.1)C0ATP200V5.42(ABFW.1)C0
FLEX100V5.42(ABUH.1)C0ATP500V5.42(ABFU.1)C0
FLEX100WV5.42(ABWC.1)C0ATP700V5.42(ABTJ.1)C0
FLEX100AXV5.42(ACFN.1)C0ATP800V5.42(ABIQ.1)C0
FLEX200V5.42(ABUI.1)C0
FLEX500V5.42(ABUJ.1)C0
FLEX700V5.42(ABWD.1)C0
===3/3 update: remove note since firmware released===
New Feature and Enhancements
N/A
Bug Fix
S=Standalone mode, C=Cloud mode
Bug fixSC
[Bug Fix] eITS#260200247, 260200387, 260200388, 260200391
a. Fix: Unexpected device reboot.
V-
Please refer to the Download Link for more details.
Zyxel Melen
«1
    edited February 11
    Does this release include the DNS problem fix that in 542ABUI0ITS-26WK06-r117894.zip ?
    V5.42 DNS is broken with FQDN objects — Zyxel Community
  • Zyxel_Melen
    Update:
    This firmware fixes the unexpected device reboot, which in most cases is caused by an abnormal FQDN object query.
    Zyxel Melen
  • Zyxel_Melen
    Hi @PeterUK
    Yes, this is included.
    Zyxel Melen
  • Zyxel_Melen
    edited February 12
    Update:
    Note: ATP500, ATP700, ATP800, USG FLEX 500, and USG FLEX 700 are excluded for V5.42 patch 1. This exclusion is due to an issue identified during internal validation, where upgrading to ZLD 5.42 Patch 1 may fail when the device is operating in an HA configuration. Once this issue is clarified and resolved, we will proceed to release the patch after the Lunar New Year holiday.
    Anyone who needs the vulnerability fix for ATP500, ATP700, ATP800, USG FLEX 500, and USG FLEX 700 without HA configuration, please download the hotfix here [Vulnerability Hotfix] CVE-2025-11730 Path Traversal Vulnerability — Zyxel Community.
    Zyxel Melen
  • mMontana
    mMontana Posts: 1,468 image  Guru Member
    All dates and timings are Central European Time
    Since Tuesday 10 7:00 a USG20W-VPN is working fine.
    Since Wednesday 10 07:30 a USG20-VPN is working fine.
    I updated roughly 1h ago a USG Flex 100, next one will be updated Saturday morning.
    And the 5.42 P0 botch has confirmed that automatic update is not the best idea for my scenarios, because current scheduling options are only weekly (and not after a configurable delay from the new version availability).
  • Sconsulting
    Sconsulting Posts: 10 image  Freshman Member
    @Zyxel_Melen when will the official fixes for the Flex500 and Flex700 be finally released? So far it still shows 5.41 as the latest firmware on these models.
  • Zyxel_Melen
    Hi @Sconsulting
    The ETA is 3/3/2026. I will also update the download link in this post.
    Zyxel Melen
  • Zyxel_Melen
    Update:
    The firmware download link for ATP500, ATP700, ATP800, USG FLEX 500, and USG FLEX 700 are released.
    Zyxel Melen
  • integratedsolutions
    integratedsolutions Posts: 18 image  Freshman Member
    Good morning, so is this a new recent update? Does it also work for Zyxel VPN 100?
  • Zyxel_Melen
    Hi @integratedsolutions
    No, this doesn't work for VPN 100 since it has reached it end-of-life status. The latest firmware version for VPN series is V5.37 patch2. You may find it via the below link.
    End of life | Zyxel Networks
    Zyxel Melen
