SecuReporter blank network activity detailed area
GiuseppeR
GiuseppeR Posts: 686 image  Guru Member
Zyxel Certified Network Engineer Level 1 - Switch Zyxel Certified Network Engineer Level 1 - Nebula 5 Answers First Comment
Hello everyone,
I went on SecuReport page to look into this amount of traffic:
And I saw the page blank:
It is the same also for Web Content filter:
Or the DNS:
But the ORG seems to be active:
How I can fix that?
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,683 image  Zyxel Employee
    Hi @GiuseppeR
    I assume you have enabled all option on the device's GUI of the SecuReporter setting.
    Please help to check if the App Patrol > Collect Statistics isn't enabled.
    If still can't find any info after few minutes, please help to enable Zyxel support access and share your organization's name so we can help to check.
    Zyxel Melen
  • GiuseppeR
    Hi @Zyxel_Melen
    it seems to me that you shared a H series UI.
    I have an ATP200 on that site:
    Fully managed via Nebula, so the only option I see is this one:
  • Zyxel_Melen
    Hi @GiuseppeR
    Thanks for the information. In this scenario, the SecuReporter will only display information when the content filter/Application patrol is set. It seems like you didn't set the content filter/Application patrol profile and apply to a security policy.
    I assume you want to check per client usage; you may check it by clicking the category hyperlink.
    Zyxel Melen
