Zyxel Flex 100H - VPN Apple mobileconfig returns error on importing on Apple OSX
MitjaS3NEXT
MitjaS3NEXT Posts: 17 image  Freshman Member
Here is the screenshot.
Apple OSX version Tahoe 26.3
  • Zyxel_Melen
    Zyxel_Melen Posts: 4,683 image  Zyxel Employee
    Hi @MitjaS3NEXT
    Thanks for sharing. After checking, the issue is due to the phase 1 Diffie-Hellman Groups. Mac OS and iOS don't support DH2 in recent version.
    Please help to remove the DH2 in phase 1 setting and add DH 19.
    Untitled Image
    Zyxel Melen
  • Zyxel_Melen
    Hi @MitjaS3NEXT
    I tried to replicate with USG FLEX 200H in V1.37 P1 and iPhone 15PRO iOS 26.3, I didn't encounter this issue. Please check:
    1. Your firewall's firmware version.
    2. Your IPSec remote access VPN advanced settings. Here is my lab's setting: image.png
    Hope this helps.
    Zyxel Melen
  • MitjaS3NEXT
    The firmware version is : V1.37(ABXF.1)
    You tryed on on the phone iOS, but the problem is on the computer Apple osX version Tahoe 26.3?
  • Zyxel_Melen
    edited February 26
    Hi @MitjaS3NEXT
    Thanks for pointing out. Let us have a further investigation.
    And the current workaround could be used the SSL VPN with OpenVPN instead.
    Additionally, MAC OS X 26.2 is working for importing the mobileconfig.
    Zyxel Melen
  • MitjaS3NEXT
    If I understand you right, you have tested on MAX OS X 26.2 and it works, but haven't tested on 26.3?
    I probably can't use SSL VPN since there is a license needed, if I understand the zyxel flex H series licensing right?
  • Zyxel_Melen
    Hi @MitjaS3NEXT
    SSL VPN on USG FLEX H series supports OpenVPN. You can import the VPN profile to the OpenVPN software.
    Not yet but is under verifying now.
    Zyxel Melen
  • MitjaS3NEXT
    Please answer if we need to buy any licenses with enabling SSL VPN on USG FLEX 100H that supports OpenVPN?
  • Zyxel_Melen
    Hi @MitjaS3NEXT
    You don't need to buy a license since OpenVPN is a free software.
    Additionally, in our test, we can import the USG FLEX 100H V1.37 Patch 1 mobileconfig file to our test MAC with MAC OS X 26.3. To investigate this issue, please help to share your mobileconfig file with us. I will send you a private message and you may upload the file in the message.
    Zyxel Melen
  • MitjaS3NEXT
    I sent you the config file as requested 👍
  • Zyxel_Melen
    Hi @MitjaS3NEXT
    Untitled Image
    Zyxel Melen
