advice on mesh
Hi @Ema65,
Welcome to the Zyxel Community!
You can achieve seamless coverage by connecting additional Zyxel access points (like the NWA50AX or NWA90AX) to the FWA 510's LAN port. Configure the additional AP(s) with the same SSID and security settings as your FWA 510 to enable proper 802.11r/k/v roaming for smooth transitions between devices.
Please note that the FWA 510 does not support Zyxel's mesh features. However, since mesh isn't required for WiFi extension, please follow the approach mentioned above first.
Zyxel Tina
- 3K Nebula
- 222 Nebula Ideas
- 619 USG FLEX H Series
- 349 Security Ideas
- 53 Wireless Ideas
- 486 News and Release
