Mirror Port XGS1930
CHGR
CHGR Posts: 3 image  Freshman Member
Hi guys, quick question:
I’m running a Zyxel XGS1930 managed via Nebula and configured Port Mirroring for Wireshark like this: Source Port 14 (uplink) → Destination Port 31 (monitor).
In Nebula I don’t see any option to select mirroring direction.
Does Nebula mirror both directions (ingress + egress), or only ingress?
If it’s ingress-only, is there any Nebula workaround to capture both directions?
    PeterUK Posts: 4,451 image  Guru Member
    The default is likely both but you should see if it is in Wireshark
  • Zyxel_Tina
    Zyxel_Tina Posts: 727 image  Zyxel Employee
    Zyxel Certified Network Administrator - Security Zyxel Certified Network Administrator - Switch 100 Answers 500 Comments
    edited March 2
    Hi @CHGR,
    Regarding your question, we confirm that port mirroring on Zyxel Nebula-managed switches, by default mirrors both ingress and egress traffic.
    Zyxel Tina
